Hope someone can help. I am replacing a light with a traditional ceiling rose with a 3 spotlight fitting. Problem is that I've lost the wiring instructions!
The wires from the ceiling are as follows:-
2 cables. Red wire from each cable joined, green cable from each wire joined, black wire from one cable, and red wire from other cable.
The spotlight has 3 wires- blue, green/yellow and brown.
Using the terminal block, what do I connect to what!
I will try and attach diagram.
I'm no sparkie so electical diagrams aren't a lot of use!
greyke[
