drilled holes too large for screw
6 posts   •   Page 1 of 1
coleby
by coleby » Sat Oct 04, 2008 1:05 pm
By mistake I have drilled holes which are slightly too large for the screws.
What is the best way to deal with this ? Put small slithers of wood in the holes or put some kind of filler in them ?
Has anybody got experience of this ?
chris_on_tour2002
by chris_on_tour2002 » Tue Oct 07, 2008 6:23 pm
use larger screws.
kitchen buff
by kitchen buff » Fri Oct 17, 2008 4:08 pm
Put a washer behind the screw head
chris_on_tour2002
by chris_on_tour2002 » Sat Oct 18, 2008 11:16 am
kitchen buff - struggling to see how that would work.
Ressy
Re: drilled holes too large for screw
by Ressy » Sat Oct 18, 2008 10:15 pm
[quote="coleby"]By mistake I have drilled holes which are slightly too large for the screws.
Has anybody got experience of this ?[/quote]
I would surgest that you drill an even larger hole about half way in the hole then put in a "plug" drill the size hole you wanted to in the "plug" and you have your problem solved. I am assuming you have some "plug cutters". Very easy if you have and keep the grain in line and it is invisible.
Ressy
CHIPPY2158
by CHIPPY2158 » Tue Oct 21, 2008 9:14 pm
when hagging doors or what ever you may be doing, if i have to pilot anything into hard timbers such as oak or close grained hardwood is to pre drill with a drill bit 2 sizes smaller than the screw. i .e if im using 1" 8s i will use a 6 mm drill!
but if you have drilled the wholes to big you shave some triangular shavings off a square sectoin of timber, n knock them into the holes! beging triangular they shud bit into the round hole! also you may wanna use dome P.V.A glue to hold them in if you wanna make a job of it
It is currently Thu Nov 21, 2024 4:33 pm
