Honeywell D200 Digital Roomstat Coonnections
alan8376
by alan8376 » Sat Oct 04, 2008 1:12 pm
My current roomstat is an old Honewell type dial model with connections 1,2,3. etc.
I,ve bought a digital type Honeywell DT200, T6620B 1008, which has a,b,c connections.
The instructions indicate I should use connections a and b, on the digital, but not sure whether 2 or 3 should be connected to b?
I have a Y Plan system, Oil boiler with a 3 Port Valve.
Can anyone advse off wiring connection?
Alan
plumbbob
by plumbbob » Sat Oct 04, 2008 5:20 pm
Can't find any reference to a Honeywell D200 thermostat is that the right number?
Can't give exact instructions as every stat is slightly different.
The three wires on your old thermostat would be live, switched live to the boiler, and neutral. When wiring to a digital thermostat the neutral is unused. The neutral would have been connected to the ballast resistor on the old stat.
Wire it the right way or it will go bang, and you will probably be buying another stat.
alan8376
by alan8376 » Sat Oct 04, 2008 9:36 pm
Not sure why I posted that model? Any way, the correct new digi stat is:
T6620B 1008.
Alan
plumbbob
by plumbbob » Sun Oct 05, 2008 12:37 am
Connect wires from con 1 to con A and con 3 to con B. Leave the third wire from connection 2 unused.
