New build - external/internal cracks
AdeJ
by AdeJ » Sun Oct 05, 2008 1:52 pm
New build, completed Sept05, internal and external cavity walls with Celcon blocks on concrete blocks below dpc - metre deep footings on sand/greensand site.
Have noticed vertical cracks externally and corresponding internally - ie cracked blocks inside and outside beneath quite large pvc casement windows. However, no diagonal cracking at the corners of windows. External rendered - internal plastered.
No cracks beneath these below DPC where Celcon meets the concrete blocked footings.
Keep being told "Just shrinkage" - but inside and outside, same locations - each about 2 metres from same corner?
Any advice very welcome, thanks.
kbrownie
by kbrownie » Tue Oct 07, 2008 8:37 pm
is it plaster or blocks that have crack new build do have some settlement time!
Kb
AdeJ
by AdeJ » Wed Oct 08, 2008 10:48 am
[quote="kbrownie"]is it plaster or blocks that have crack new build do have some settlement time!
Kb[/quote]
The blocks have cracked - have cut back the render on outside and plaster on inside and the cracking is clearly visible in the blocks - sometimes down the mortar line but then across the blocks themselves. Someone has said this is normal - but will it ever stop happening?
kbrownie
by kbrownie » Thu Oct 09, 2008 12:31 pm
If the problem is settlement, this does happen in new builds and will stop.
KB
AdeJ
by AdeJ » Fri Oct 10, 2008 3:57 pm
[quote="kbrownie"]If the problem is settlement, this does happen in new builds and will stop.
KB[/quote]
Thanks for the reassurance - will keep an eye on it. :)
It is currently Sat Nov 23, 2024 4:54 pm
