Sliding wardrobes
Questions answered and a range of solutions on problems and issues encountered with timber framed buildings
studog
Sliding wardrobes
by studog » Tue Oct 07, 2008 3:17 pm
Hello knowledge masters!!!
I am looking to fit myself a sliding wardrobe at the end of my bedroom and I want it to be a mirrored one. So I research buying "pre fabed" doors and the largest I can get for a decent price is 2500mm high. My house is a really old back to back and the floor to ceiling measurement is 2800mm.
I'm having trouble figuring out how I will fit them... will I have to build a platform at the bottom 300mm high? also would you advise to build a structure on the inside and line it so that my clothes etc are not in contact with the wall?
All help/ideas/advice is welcome on this one, it's my first go at joiney, so i'm slightly apprehensive!
Regards,
Stu
TheDoctor4
by TheDoctor4 » Tue Oct 07, 2008 4:38 pm
Have you had a look at the DIY Projects area: https://www.diydoctor.org.uk/projects.htm There is a project called "Sliding wardrobe doors" that offer you some help and advice.
Regards
laorc
Re: Sliding wardrobes
by laorc » Sat May 12, 2012 8:47 am
I would build a header at the top rather than building up from the bottom, if you have a section at the bottom you will find you will trip on it. I think a company called spaceslide do doors upto 2800 high might be worth looking at them and you wont need a header
It is currently Mon Nov 25, 2024 11:02 am
