Draughts from air bricks
northumbrian lad
by northumbrian lad » Wed Oct 08, 2008 10:34 pm
My house is a standard 1970's brick detached.
We seem to be losing a lot of heat via the suspended timber floor. I'm masticing up the floor / skirting joins up as & when I can, but the main area of concern is the amount of air flowing under the floor due to the air bricks. The house is an "off the shelf" design, in an exposed location, so we get a lot of wind !
What I'd like to do is fit some sort of baffle to the airbricks so that they flap shut when the wind gusts against them, but remain normally remain in the open position for ventilation purposes.
Is there anything out there that would do the job, or has anyone got any alternate ideas ? It's too disruptive to do the ideal & fit underfloor insulation, & the project manager advises me she won't countenance any restriction to the airflow that I devise - it's got to be something "proper"
air bricks
by welsh brickie » Thu Oct 09, 2008 1:11 pm
You could fit hit and miss sliding vents to the airbricks.
they can be shut in high winds i suppose, there not designed to be fitted externally but could work,or fit a mesh over the air bricks .
It is currently Sun Dec 22, 2024 2:01 pm
