Motorised valves restrict flow
billandben
by billandben » Thu Oct 09, 2008 5:42 pm
I've just bought a 22mm Drayton 2-port motorised valve and noticed that although the inlet is 22mm, the outlet seems to be restricted to about 15mm, thereby halving the throughput. This seems to be a bad design. Can anyone recommend a 2-port valve that actually has a full 22mm bore
thanks
plumbbob
by plumbbob » Fri Oct 10, 2008 8:54 pm
Honeywell do a two port zone valve which if I remember right is full bore.
I prefer them anyway.
Screwfix part no 31480
It is currently Fri Nov 22, 2024 11:44 pm
