by screenlux »
Mon Oct 13, 2008 10:27 pm
[quote="htg engineer"]It's unlikely (not impossible) that both the motorised valves will be faulty. When the heating goes off but wont come back on - have you checked the room stat isn't keeping the heating off ?
I'd be looking towards time clock / programmer.
htg[/quote]
The hot water valve is faulty (see my reply to screech) but the fact that the central heating only comes on when the hot water has been on then off does point to a programmer problem. When doing the checks the room stat was set to max as was the tank stat and boiler temperature as I wanted to be sure they all should be on. Thanks.
I think I will replace both the valves and the programmer just to be sure.
