by williamj »
Fri Oct 10, 2008 6:14 pm
I wanted to move a ceiling light about 14" to one side. On dismantling the existing lampholder, I could see that there were three earths, three lives and three neutrals. The earths and lives were all twisted together and two of the neutrals. The third neutral was connected to the "third" connection on the top of the lamp holder. There was no ceiling rose. I marked the single neutral wire. In the new required position The wiring in the attic directly above neft me enough slack to simply drop the wiring through the new hole. I fitted a new ceiling rose. I secured the three earths to their connection. Then the three (red) lives to the central three connection points on the rose. I connected the two neutrals which were originally together to the other set of three points on the rose. The single marked neutral I connected to the pair of two on the rose. I am getting power to the bulb but cannot turn it off!! Clearly I have got something connected in the wrong place but try as I may, I cannot get it right. Any ideas please?
