radiator valves
7 posts   •   Page 1 of 1
bezthedog
radiator valves
by bezthedog » Sat Oct 11, 2008 3:04 pm
Hi i am wanting to replace a couple of radiator valves the trouble is i dont want to drain the system if possible. i have heard you can buy a spray that freezes the pipe for about 20 mins while you work on the radiator is this true
Thanks :oops
Steve the gas
by Steve the gas » Sat Oct 11, 2008 8:40 pm
Sort of ............. but I wouldn't bother.
If your'e not confident get someone in by recomendation.
screech
by screech » Sun Oct 12, 2008 12:37 am
Search Screwfix for "Pipe Freezing Kit"
never used the stuff myself, but also never drain a system. i also bung it and create a vacuum instead.
by htg engineer » Sun Oct 12, 2008 12:51 pm
So you freeze the water - fit the new valve, what happens if one of the joints is leaking ?
You cannot freeze moving water, draining takes time - carpets/flooring ruined ????
htg
plumbbob
by plumbbob » Sun Oct 12, 2008 6:24 pm
I only use freeze kits if I think a) if they will work, b) alternatives are likely to be awkward.
You cannot freeze close to the working area and won't work reliably in vertical pipes.
Freezing is difficult, unreliable, and expensive. One £6 can freezes one 15mm pipe for 20 mins (you hope) so two rads = 4 pipes = £24 and there is no guarantee it will work.
If you have a pressurised system simply dropping the pressure and emptying the rad may be sufficient to stop any water escaping so you can change the valve.
Best way to a heart attack is to freeze a pipe then get stuck trying to do the new connection.
chris_on_tour2002
by chris_on_tour2002 » Thu Oct 16, 2008 6:56 pm
you can also be overzealous with the freezing agent, overexpand the water and burst the pipe - as happened to me recently when changing a stuck gate valve on a CWSC mains feed. had to use another freezing kit to repair the damaged pipe!
not for the uninitiated.
plumbbob
by plumbbob » Fri Oct 17, 2008 6:24 pm
Not for the faint hearted either.
It is currently Fri Nov 22, 2024 12:00 am
