bath and basin waste ?
6 posts   •   Page 1 of 1
tony636
by tony636 » Mon Oct 13, 2008 7:04 pm
hello, i'm going to be changing the waste pipes in my bathroom, the basin is running at 32 mm and the bath is running at 40 mm. thats not he problem, they both enter the soil sack, bath waste is lower, then the basin waste comes in about 350 mm higher up. Can i use 40 mm for the bath and as it runs past the basin, drop the basin waste into the same pipe using 1 pipe for both flows? please help. :?
chris_on_tour2002
by chris_on_tour2002 » Mon Oct 13, 2008 11:20 pm
i see no problem with running the 32mm into the 40mm. if it were the other way around, ie 40mm down to 32mm then it may be a problem as it may cause your bath water may drain very slowly.
Steve the gas
by Steve the gas » Tue Oct 14, 2008 5:20 am
I have so yes, it works fine.
plumbbob
by plumbbob » Tue Oct 14, 2008 1:30 pm
Sorry to disagree with everyone else, but although sometimes you have to combine wastes, it is not good practice to do so. Two problems occur. Firstly, when the plug is pulled in a full basin, water will often flow up the bath waste and cause a gurgle in the trap. sometimes water can actually flow up into the bath. Secondly, when the basin empties, and the water drains away, it can pull all the water out of the bath trap breaking the seal and allowing odours up into the room.
bobbych
by bobbych » Tue Oct 14, 2008 3:44 pm
its fine to do as yu say but 1 consideration is if the bath drains fast it may try to pull the water seal from the basin trap. It may gurgle. If it does you can fit an anti vac trap to the basin
tony636
by tony636 » Tue Oct 14, 2008 10:01 pm
:D thank you to the guys that have sent me replies to my question .
It is currently Fri Nov 22, 2024 2:03 am
