Problems with my Cascade Mixer Shower
Rookie1977
by Rookie1977 » Tue Oct 14, 2008 5:28 pm
Initially the shower would not turn off properly and water trickled out even when firmly turned off. Now I need to use a screwdriver to turn the shower on and off/change water temp. Can I fix this?
bobbych
by bobbych » Wed Oct 15, 2008 9:50 am
I think your valve need a service. You can get seal kits for most valves. Most valves can be dissmantled quiet easily, cleaned & seals replaced
It is currently Fri Nov 22, 2024 1:42 am
