toilet doesnt fill then over flows
seagal
by seagal » Thu May 10, 2007 4:11 pm
hello i have a sanitop with a split push button cystern. when i try to flush the cystern is empty i have to slide the plastic loat down but then it over flows i have to keep moving it up and down until it stops i am concerned it will break as it is only plastic please help thanks all xxx
thedoctor2
by thedoctor2 » Thu May 10, 2007 7:08 pm
Think the easest answer to that is replace it , they only cost pennys and saves a lot of bother to from the wife
seagal
re toilet
by seagal » Thu May 10, 2007 7:12 pm
thnks for your reply any idea if it is different from normal toilet floats and is it difficult to get as it its a sanitop toilet? thanks x
Arnak
Toilet problem.
by Arnak » Sat May 12, 2007 12:00 pm
Yes the float in those type of cisterns is different to the standard type.
Are you sure that the float is the problem as the float operates a valve?
It sounds more like the valve is faulty.
I'd suggest either getting a plumber to have a look or contact saniflow for a repair kit.
A lot of the big manufactures have web sites with fitting diagrams and a spare parts list so you may be able to order direct or they will have a list of suppliers.
Arnak
It is currently Fri Nov 22, 2024 11:20 am
