decorating
LES EATON
decorating
by LES EATON » Fri Oct 17, 2008 2:20 pm
How late in the year is in feasible to paint outdoor surfaces (eg window frames) :?: [color=red][/color]
kevinfoot
outside painting
by kevinfoot » Wed Oct 29, 2008 1:04 am
Hi Les
You can paint outside anytime as long as:
1) The temperature does not drop below 5 degrees C (including drying times)
2) The relative humidity (important) does not go above 80%
3) The wood (substrate) is dry
kevin Foot
078 333 14008 decorator
chris_on_tour2002
by chris_on_tour2002 » Wed Oct 29, 2008 11:02 pm
and you are not expecting frost. it kills wet paint and will never dry if frozen whilst wet. and it's an awful job to remove it.
It is currently Fri Nov 22, 2024 5:29 pm
