by chris4020 »
Wed Nov 12, 2008 8:22 pm
[quote="DAVEYD"]I have recently had Magnaclean fitted and notice that the bleeder valve has a screwtop type fitting which my standard bleeder key will not fit. Will I be able to bleed the unit with a screwdriver[/quote] hi you can`t use a screwdriver to bleed your magnaclean all you need is a normal radiator bleed key which will work fine. Google "adeysolutions.co.uk"
