Can I run a boiler and a tumble dryer from one socket?
scouse7
by scouse7 » Sun Oct 19, 2008 10:32 pm
Is it feasible to have a boiler and a tumble dryer running on one socket using a two-way adaptor? :?
by ericmark » Mon Oct 20, 2008 3:40 am
If you are referring to a gas, oil or solid fuel boiler then it would likely work OK however if the boiler takes its power (rather than control) from the socket then it could be overloaded.
Most electrical items will have a plate somewhere giving the power they use problem for house holder is this is normally in watts not amps.
So 230 watts = 1 amp so 13 amp = 2990 watts normally considered as 3kW if you add all the watts and it is under 3000 or 3Kw then it will work OK.
Eric
scouse7
by scouse7 » Wed Oct 22, 2008 7:32 pm
Thanks eric. Power output for the boiler is 190 Watts and the dryer is 2400 Watt Max so it should be okay.
It is currently Wed Feb 05, 2025 3:47 pm
