Water overflowing from Toilet Cistern into overflow pipe
KeithLancashire
by KeithLancashire » Mon Oct 20, 2008 2:42 pm
The water level is rising too high when the cistern refills after flushing so the excess overflows into the outside pipe.
Under the old system I could adjust the ballcock arm which I think was copper but the modern cistern has plastic components
There is a white plastic arm then a red joint below it and the blue ballcock screws into the red joint.
How do I adjust the ballcock so that the water stops coming in before it reaches the height of the overflow pipe. :?:
bobbych
by bobbych » Tue Oct 21, 2008 4:44 pm
See where the arm pivots at the valve, just above the pivot you should see a plastic screw which when turned changes when the plunger is closed so closing the valve
I can prob send you a pic if needed
KeithLancashire
by KeithLancashire » Tue Oct 21, 2008 5:54 pm
Thanks. :)
Please send Pic
It is currently Sun Nov 24, 2024 10:12 pm
