tiling on tarmac
Mo
tiling on tarmac
by Mo » Thu May 10, 2007 8:52 pm
i have an old tarmac patio about 50m2. is it possible to tile on top of the tarmac. ideally without having to concrete over it.
Mo
thedoctor
by thedoctor » Sat May 12, 2007 10:43 am
Presuming you mean paving slabs Mo, yes its usually ok. The slabs should be laid on a bed of sharp sand and cement approx 50mm thick and mixed at 8 to 1. The mix should be damp but not wet which will allow it to dry fairly flxibly and take up any movement in the driveway below caused by varying temperatures,
It is currently Fri Jan 31, 2025 1:16 am
