combi bolier
lee.t
combi bolier
by lee.t » Thu Oct 23, 2008 6:57 pm
i have a ideal isar boiler that has gone off for no reason there seems to be power going to it and it was working today could there be a fuse inside that has blown
by htg engineer » Fri Oct 24, 2008 10:40 am
Could be - but why ? fuses don't normally blow for no reason.
Has the boiler been noisy lately ? more noticeable outside - maybe the fan. Inside ? maybe the pump.
There'll probably be a quick blow fuse (2amp) at the electrical connection to the boiler or on the PCB.
What's the pressure like ?? should be between 1.0 and 1.5 bar. If it#'s lower this could be why it's not working. Read instructions to see if there's any manual resets on the boiler.
Unsure - get an engineer. If you mess on you could make the problem worse and alot more expensive. Especially if you cause damage to the PCB.
htg
It is currently Sat Jan 11, 2025 4:45 am
