i recently replaced the pressure relief valve on my halstead ace high boiler because the pressure kept dropping everyday, now when the central heating comes on the pressure drops and have to keep topping up. When using only hot water pressure is ok.
pressure is ok when only using hot water but as soon as CH is on presure will drop, what could be the problem, plz advise in detail.
could there be a leak in the CH and how to fix? how to check for leak in CH?
Other fault why bolier is losing pressure when heating is on. please advise. thanks
