penetrating damp?
wyorksla
penetrating damp?
by wyorksla » Sun Oct 26, 2008 6:14 pm
I recently moved to an 1890s mid-terrace. The external wall of our rear extension shows signs of damp and salt deposit at a height of around 1m in a wall that was recently replastered. The research I'm doing suggests this is penetrating damp. There is no visible sign of wall damage from the outside, other than a general deterioration of the surface of the original brickwork, or of a specific place where ingress could be occurring, so I am considering a salt neutraliser and then painting Ultra Proof outside. Does this sound a reasonable diagnosis and course of action?
Thanks!
damp
by welsh brickie » Mon Oct 27, 2008 9:29 am
sounds like a bridged wall tie,spray the entire wall with a silicone based clear solution this will solve the problem but only a temporary one
wyorksla
by wyorksla » Mon Oct 27, 2008 2:00 pm
I should have mentioned that the extension is an old one - hence no cavity. Am I right in thinking this means there won't be any wall ties?
id99999uk
possibly rising damp
by id99999uk » Tue Nov 11, 2008 3:41 pm
as the damp is evidenced up to 1m it sounds like rising damp . check for a bridged/ failed damp course , is it still wet, painting over the problem will not solve it
Paul
TheDoctor5
by TheDoctor5 » Fri Jan 30, 2009 9:31 am
It is currently Mon Nov 25, 2024 7:12 pm
