dividing wall
kinglouie
dividing wall
by kinglouie » Fri May 11, 2007 7:04 am
hi i need to build a dividing wall that is approx 13ft long and 5ft high,do i need to incorporate more than two piers(ie at both ends)and as its my first attempt at wall building what is the best design for the piers,any help greatly appreciated :)
thedoctor
by thedoctor » Fri May 11, 2007 7:10 am
Yes a pier at each end will be required and its much easier to buy a book on basic brickwork to see the bond you will need to build a pier. Its not something that can be explained in text and we do not have any brickwork projects yet. Go to the brick and blockwork section of the bookstore
simplysimon
by simplysimon » Mon Jun 04, 2007 1:00 pm
you need nothing if internal. Its all about where your building it and wall thickness. more info pls
It is currently Tue Jan 07, 2025 3:38 am
