Main light in living room is 'pulsing'.
6 posts   •   Page 1 of 1
meldrew21
by meldrew21 » Mon Oct 27, 2008 10:21 pm
Hi guys, we don't use our main centre light in living room often. When I switched it on recently it was pulsing. Is this a common fault?
Thanks in advance
Kev
by ericmark » Wed Oct 29, 2008 9:06 am
Only with dimmer switches. Sometimes the coiled coil of the bulb causes the dimmer to malfunction changing make of bulb normal cures it.
Eric
meldrew21
by meldrew21 » Wed Oct 29, 2008 11:36 pm
Thanks for replying, Eric. I've tried a couple of different makes and type of bulb but get the same problem. I'll continue to swap some bulbs around tomorrow to see if it stops.
In the meantime I'd like to ask ...is it possible that the dimmer is playing up? I'd be happy to replace it if that fixes the problem.
Kev
by ericmark » Thu Oct 30, 2008 8:13 am
Yes very likely but no guarantee
meldrew21
by meldrew21 » Thu Oct 30, 2008 12:11 pm
Cheers, Eric. Thanks for your help.
meldrew21
by meldrew21 » Mon Dec 08, 2008 11:52 am
Replaced the switch and problem cured. Cheers, Eric.
It is currently Sat Nov 23, 2024 11:38 pm
