New Radiators taking ages to get hot - flow/return problem?
steveeckersley
by steveeckersley » Tue Oct 28, 2008 9:15 pm
[b][/u]New radiators take ages to get hot
We have had two new radiators fitted in a new Kitchen and conservatory. All others are working as normal, the new ones eventually get hot but there is a massive difference in temperature between the flow and return pipes (flow mega hot, return almost cold). Cannot understand how rads get hot but pipework so different in temperature. Turned all the others off to try and force them, bled several times, run out of ideas. Can anybody help please. [/u][/b]
chris_on_tour2002
by chris_on_tour2002 » Wed Oct 29, 2008 10:52 am
sounds like the lockshield valves (on the return side normally) are almost closed. might be obvious but have you checked?
failing that your system may need to be balanced to account for the additions of two extra rads.
nitro23456
by nitro23456 » Wed Oct 29, 2008 11:46 am
whats your pump set at? you could try to turn it up to see if this helps.... are the new rads completely new? - ie has the system been extended to add these new rads?
bobplum
by bobplum » Wed Oct 29, 2008 9:44 pm
hi
the first two replys are right but can i ask how many rads you now have in total,could be too many?for the system
bob
steveeckersley
by steveeckersley » Thu Oct 30, 2008 11:52 pm
[quote="bobplum"]hi
bob[/quote]
Thanks everybody for all the replies and tips, did the checks, found it was a case of balancing the original radiators to account for the two new ones added. The place is now lovely and warm which is good as its freezing outside! Thanks again, Steve
It is currently Sat Jan 11, 2025 7:50 am
