Adding a spur to run cable to outside socket
lmikosz
by lmikosz » Fri May 11, 2007 11:11 am
Hello, can anyone tell me whether there are special regs regarding adding a spur that will run to an external power socket. Also, whilst I understand fully how to add one spur how do you add two spurs in order to have a double socket?
by sparx » Fri May 11, 2007 4:33 pm
A spur can be 1 single or 1 double socket on one 2.5mm cable.
You do know of course you can't fit outside socket yourself as this is a 'controlled service' under bldg regs part p,
Regards SPARX
lmikosz
by lmikosz » Fri May 11, 2007 7:27 pm
Sheesh, part P is pretty restrictive. Would an Electrical Engineer for the CAA be able to self certify?
by sparx » Sat May 12, 2007 10:46 am
No!
regardless of other qualifications must be registered with one of the self certification bodies, Regards SPARX
It is currently Mon Jan 06, 2025 2:20 am
