Two ovens on one circuit
tonyfitz
by tonyfitz » Fri Oct 31, 2008 3:35 pm
Having a new kitchen fitted and it will have two ovens. One fan assisted and one combination microwave. Existing cooker fed from new consumer unit via 32 amp MCB and 6mm cable. Both new ovens draw max 16 amps. Is it ok to connect both to existing cable (via separate 20 amp double pole switches) or should there be additional protection?
by ericmark » Fri Oct 31, 2008 9:58 pm
The switches would need to be over 32 amp i.e. 40 amp and as to if two can be feed from same supply depends on manufactures recommendations and I would think two separate supply's would be required.
Eric
PS are you aware of Part P
tonyfitz
by tonyfitz » Sat Nov 01, 2008 1:12 pm
Thanks for that EricMark. Will check with manufacturers but sounds like second feed is the best option. Yes - very much aware of part P and all work being done will be properly certified,
It is currently Mon Jan 20, 2025 9:06 am
