Quadrant shower tray installation
7 posts   •   Page 1 of 1
carruthers
by carruthers » Sat Nov 01, 2008 2:46 pm
Does anyone have the answer to the finishing of the 'skirting' finish to a quadrant stone cast shower tray that has to be raised to accommodate the waste. The floor is concrete. I can't seem to find anything in the DIY sheds, that is made for the job.
Any suggestions? Please
forrest38
by forrest38 » Sat Nov 01, 2008 7:51 pm
hi
I work in a plumbers merchants. All you need is a flexible plinth. That's what it's called. Just have to go to any plumbers merchants. Might need ordered in depending on size.
Skids
by Skids » Sat Nov 01, 2008 8:10 pm
Hi carruthers
Go to one of those ‘guttering’ or ‘plastic cladding’ outlets, they usually have a wide choice of strips that will suit.
Regards
Skids
bobplum
by bobplum » Sat Nov 01, 2008 10:40 pm
hi
is it possible to place hardboard between floor and shower tray set back a few mm and then tile over with mosaics tiles
bob
carruthers
Shower tray
by carruthers » Mon Nov 03, 2008 1:36 pm
Many thanks for the responses. I hadn't thought of the plumbers merchants :oops:
Curruthers
chris_on_tour2002
by chris_on_tour2002 » Mon Nov 03, 2008 7:13 pm
check with the supplier of your tray - some manufacturers will make them, it might be possible that you can buy one for your particular model.
plumbbob
by plumbbob » Mon Nov 03, 2008 10:45 pm
Go with Skids option of UPVC soffit board which is only a few quid. The plastic trims are identical in colour and texture to shower trays.
It is currently Tue Nov 26, 2024 12:06 pm
