Gaps in Ceiling Tape in New build house
HelpDIY?
by HelpDIY? » Fri May 11, 2007 2:13 pm
I have a new build house(3yrs old) where the builders have used ceiling tape. Although the ceiling tape is NOT coming away, there are definite "gaps/cracks" where the tapes are. What is the recommended process to fill this in? When I had my 6month shrinkage check up - they re-plastered these areas - but I wondered if I could use some filler? If so, what is the recommended one?
thedoctor
by thedoctor » Fri May 11, 2007 5:32 pm
The most flexible filler is the decoartors caulk or "filler in a tube" in our filling cracks around the house project . You will neeed the applicator gun also. Its easy to apply and when puished into the gaps actually moves as they expand and contract so will last much longer than a rigid filler.
HelpDIY?
by HelpDIY? » Mon May 14, 2007 10:07 am
Thanks for the reply.
What if the ceiling tape is coming away? Do I glue it back? and if so with what? or can I apply some plaster or filler to go over the top? I have a friend who had exactly the same problem, and they tried to pull the tape off completely and made the situation much worse!!
Thanks!
thedoctor
by thedoctor » Mon May 14, 2007 11:22 am
The tape is usually applied at the same time as the plaster and the best bet here would be to use a little of the flexible filler, spread out a bit, to stick the tape back down, then plaster over it.
It is currently Thu Dec 12, 2024 3:30 pm
