Hot Neutral pin on Plug
Shirley
by Shirley » Fri May 11, 2007 2:47 pm
We had a waterproof Socket fitted in our Greenhouse by an Electrician and the first Socket burned out within a week so he changed it for a new one.
That was a couple of years ago, this socket was for a 3kw heater now when we tried to remove the plug we have found that the Neutral pin on the plug has melted the plastic on the socket.
What would have caused this? it didn't cause the fuse or the trip to go.
there was no sign of a problem until we went to remove the plug.
Shirley
thedoctor2
by thedoctor2 » Fri May 11, 2007 3:33 pm
Wood suggest that you get your sparks to change your socket there to or better still install a fused spur outlet .heat can build up due to poor contacts or over loading
Shirley
by Shirley » Fri May 11, 2007 3:53 pm
[quote="thedoctor2"]Hi
Wood suggest that you get your sparks to change your socket there to or better still install a fused spur outlet .heat can build up due to poor contacts or over loading[/quote]
Thankyou for your prompt reply.
There are 2 sockets and one had the 3KW heater on and the other had a Grow Light on so perhaps it was overloaded.
We will have to get an electrician in.
Shirley
It is currently Mon Nov 25, 2024 4:06 pm
