PUMA COMBI - Can get C/H Though Cannot run a Hot Bath HELP!!
nashy
by nashy » Mon Nov 03, 2008 12:22 pm
Hi Guys
I have a PUMA COMBI boiler - and it kinda works fine
though one thing i cannot get is a constant flow of hot water for a bath for example
Heating works fine - I think one radiator in the spare room doesn't give out much heat - could this affect the hot water???
Should i have my thermostat set to a certain number
Sorry I'm a dizzy moo, but any help would be awesom
Tammy :wink:
by htg engineer » Mon Nov 03, 2008 4:26 pm
Can you be more precise with the problem.
You get warm water ? cold water ? water keeps going hot and cold ?
Try closing the tap slightly to reduce the flow rate through the boiler, doe the water get and stay hot ?
htg
nashy
by nashy » Tue Nov 04, 2008 12:04 pm
Thanks so much for coming back to me
Now i have enough hot water to do the washing up
But i'll go upstairs start running the bath - gets hot Happy Days!!!
I'll pop back in after 5 mins and it's run cold
So gets hot but for a very short time then goes cold, but the central heating works fine -
And pockets are quite skinny so hoped i could avoid Plumber Boy
Tammy :wink:
