Flue liner noise
derby ram
Flue liner noise
by derby ram » Mon Nov 03, 2008 7:28 pm
Hi, just had a new gas fire and surround fitted. Got convinced by the installer that I needed a flue liner (not cheap). He removed my clay chimney pot and put a small Stainless steel cap on top. But now when it is windy can't hear the television for the noise. He says not a lot he can do, surely there must be something, anyone help/advise ?
TheDoctor5
by TheDoctor5 » Fri Jan 30, 2009 10:57 am
DEEARR2
by DEEARR2 » Fri Jan 30, 2009 10:20 pm
There are a number of compliant flue terminals that would suit this application. The installer could have checked and found one that would have reduced the wind noise.
It is currently Sat Nov 23, 2024 5:23 pm
