cap off gas fire
derby ram
cap off gas fire
by derby ram » Mon Nov 03, 2008 7:32 pm
Hi, I have an old gas fire in dining room that I want to dispose of. Problem is there is no iso valve. Can I turn off gas, remove fire and install a valve and cap off, I am a mechanical engineer and very competant. Corgi man wants £80 to do it (15 minute job). If I can do it myself what are the best fittings to use, Compression/Solder ring ?
Steve the gas
by Steve the gas » Tue Nov 04, 2008 5:45 am
Only a corgi should do this, but,as you say your competant (and thats what HSE say) Gas off and compression stop end IF its accessable.But you need to test before and after, so back to a corgi me thinks.
TheDoctor5
by TheDoctor5 » Fri Jan 30, 2009 10:58 am
It is currently Sat Nov 23, 2024 5:05 pm
