The hot water heating system has been working fine. The circulating pump started to fail so I replaced it with a new one. Due to the pump age a direct was not available so I was given a replacement that had slightly more capacity. The new pump has a 3 position switch to control speeds and I set it on the middle one. All went well, except the last radiator in the system was not getting hot. I decided to slow the new pump down and then the radiator got a bit hotter but still not to the top. I have tried your suggestions on balancing but still the same.
Any suggestions will be very welcome, as I am stumped as what to do next.
