Painting onto old plaster
7 posts   •   Page 1 of 1
jamieb
by jamieb » Thu Nov 06, 2008 7:20 pm
I have just stripped wallpaper that has been in place for about 6 years and am wanting just to paint the bare walls. The walls are in fair cindition but I want to ensure a good finish. Is there anything in particular I need to consider before I start?
Any advice greatly appreciated.
chris_on_tour2002
by chris_on_tour2002 » Thu Nov 13, 2008 10:17 pm
firstly ensure that all wallpaper adhesive is removed. give them a light 'denibbing' sand all over then apply a watered down matt emulsion to seal, 60% paint to 40% water. allow to dry then go ahead and paint as normal.
jamieb
by jamieb » Fri Nov 14, 2008 7:40 pm
Thanks for this. Instead of watered down paint I've already bought some PVA. Will that be ok?
Thanks again.
chris_on_tour2002
by chris_on_tour2002 » Mon Nov 17, 2008 12:13 am
probably not. the glue will cause the paint to crack once dry.
however you can add a very small dollop of pva to the water prior to mixing with paint to dilute. i find this works very well.
yeratit1
Painting to old plaster
by yeratit1 » Mon Jan 19, 2009 11:21 am
My girlfriend want to paint directly onto the walls in our spare room, however it had 3 layers of wallpaper on it since the 60's once removed the plaster below is in fair condition with on major damage. Is there something I can do to prepare the wall and smooth it out so I can get a good finish or do I need to call the plasterer in?
TheDoctor5
by TheDoctor5 » Mon Jan 26, 2009 9:13 am
rigga
by rigga » Tue Feb 17, 2009 9:00 pm
yeratit1, You can remove all old paste by washing down all walls using clean water and scotch bright (square pieces of scourers) to remove stubborn paste. Be careful with light switches and sockets when using any water to wash down with. Then use any brand of good quality vinyl matt emulsion as a finish, if using vinyl silk use vinyl matt as a first coat. these walls should not be hot afer all these years so no need to thin the first coat.
It is currently Sat Nov 23, 2024 6:44 pm
