Sorry I mucked up, I posted the following as a response to myself instead of as a new topic. I'll get the hang of it soon?
I am now very close to having our system working i.e. I now have the submersible pump (whale 881) in the butt and on its own it is filling the cistern no problem. Next I have piped in a T to take the pressure switch. I have been given 2 to try; both are adjustable: 0.11 - 0.4psi and 1.0 - 4.0psi respectively and both have Common, NC (‘normally closed’) & NO (‘normally open’) terminals. In both cases I am getting the same result: if I use the Common/NC option the switch clicks on and off repeatidly making the pump works but it hunts/pulses and is very slow no matter how I adjust the pressure range but, it does stop when the cistern fills and starts again on demand. If I use the Common/NO option the switch is silent and the pump runs very smoothly and fast but once the cistern fills and the valve closes, the pump carries on pumping no matter what setting I try on the pressure adjustment. My guess is that the Common/NO option is the correct wiring option but neither switch is the right one (PSI range) to suite the whale pump I have.
By the way I did consider using a level switch to control the on/off function but, unless there is a wireless version, to wire in the switch (based in the cistern) back to the pump would be difficult to put in place so hence the pressure switch idea.
Does anyone know how the pressure switch works i.e. from the point of which of the NO or NC options is the right one to use and why?
Thanks again
