by nitro23456 »
Wed Nov 12, 2008 10:21 am
If you dont feel confident dont touch it.
You would normally have four pipes at your cylinder in your airing cupboard - see picture:
https://www.diydoctor.org.uk/project_ima ... linder.jpg
The hot water shut off is normally on the pipe run somewhere that is labelled '2' in that picture above. It might be higher up that pipe though, but still on that pipe somewhere (maybe even ceiling height or even in the loft as Bob said). Also remember that your cylinder might be in a different orientation than that of the picture i.e. pipe '2' might appear on the left in your house and not right as pictured and 3 and 4 might be on the right (3 and 4 are return and feed from the central heating respectively that heat the water)
So if you shut off pipe number 2, you stop cold water from the loft tank entering the cylinder at the bottom. Normally when you open a hot tap hot water leaves the cylinder by number 7 as cold from the loft (via pipe 2) pushes the hot out of 7 via the height (and thus pressure) of the loft tank water pushing down. If you isolate pipe 2, this cannot happen. The cylinder is still full of hot water but it cant go anywhere as it cant be pushed out via the 'head' of water from the loft tank. So if you now turn the hot tap on, you will get a trickle for say 30 secs whilst the water already in the pipes empties - it will then stop.
If your still in doubt, post a picture and Il tell you which to shut off.
