balancing radiators with TRVs
8 posts   •   Page 1 of 1
bikeman
by bikeman » Sun Nov 09, 2008 12:46 pm
My radiator system is microbore.
Some radiators have Honeywell TRVs
These TRVs can apparently be fitted on either inlet or return pipes.
3 of my TRVs are fitted to return pipes and these radiators all fail to heat up properly and are cool at the bottom. Presumably because water is escaping too quickly and these radiators need balancing.
The question I have is how do I balance these radiators with the TRV on the return pipe? There doesn't seem to be any adjustment to restrict flow.
thanks
nitro23456
by nitro23456 » Sun Nov 09, 2008 1:06 pm
you've lost me.... the TRV restricts the flow
bikeman
by bikeman » Sun Nov 09, 2008 1:11 pm
[quote="nitro23456"]you've lost me.... the TRV restricts the flow[/quote]
Stands to reason that if fitted to the return pipe the TRV still needs to be adjusted to balance the radiator.
bikeman
by bikeman » Sun Nov 09, 2008 1:22 pm
Just noticed, below the trv head the pin is surrounded by a plastic collar markerd 1-10 which can be turned down/up. Is this the flow adjustment for balancing the TRV?
bobplum
by bobplum » Sun Nov 09, 2008 1:26 pm
hi
you can have trvs that work on the flow or return
it may be a case that your ones are not designed for this
why not swap them around and start again
bob
bikeman
by bikeman » Sun Nov 09, 2008 3:20 pm
if the moderator actually allows me to post - for anyone else who wants to know the trv has a restrictor adjustment below the valve head which is used to adjust balance.
by htg engineer » Mon Nov 10, 2008 11:47 am
Balance the system using the lockshield valves.
htg
joanne robertson
Re: balancing radiators with TRVs
by joanne robertson » Mon Nov 10, 2008 4:12 pm
you need to balance the system using he lockshield valves which are the valves on the opposite end to the TRV's
It is currently Sat Jan 11, 2025 7:05 am
