Gas pipe through the wall from meter??
Bobins
by Bobins » Wed Nov 12, 2008 5:20 am
hello,
I'm in the process of getting my central heating sorted out and the corgi bloke's comin in about 2 weeks, prior to him coming round i am gonna drill my outside wall through to under my floor for the 22mm gas pipe to come through from the meter, however close the meter box is the wall brick vent thing to under my house, i am wandering if i can knock a bigger hole in that and feed the pipe through there or will i need to drill the wall?
cheers.
TheDoctor5
by TheDoctor5 » Fri Jan 30, 2009 11:00 am
It is currently Fri Nov 15, 2024 7:49 am
