Dot & Dab - internal window plasterboad advise?
worm
by worm » Wed Nov 12, 2008 1:23 pm
I've just had my kitchen window moved and fitted!!!
Now in the process of boarding out the internal surfaces.
All is complete bar the sill?? There is still the cavity exposed, what is the best solution to use here to fill cavity?
Expanding foam? However may all just drop down cavity....so loads will be required!!!
Pack it out??? Advice please so I can finish this job!!
There is no external cavity to rest the board on, so really need this cavity to be ridgid as poss!!!
many thanks
ollyburton
Re: Dot & Dab - internal window plasterboad advise?
by ollyburton » Thu Nov 13, 2008 3:26 pm
worm wrote:I've just had my kitchen window moved and fitted!!!
many thanks
hello there you need cavity closers they are rigid plastic strips which fit into cavity screwfix or builders merchant should stock them you need to measure cavity width.
________
GAA engine
TheDoctor5
by TheDoctor5 » Tue Jan 27, 2009 2:07 pm
It is currently Fri Nov 22, 2024 1:22 am
