loft floor joists
billyboy999
loft floor joists
by billyboy999 » Wed Nov 12, 2008 6:54 pm
how far apart should the bolts be when bolting new joists against old ones in loft conversion
ollyburton
Re: loft floor joists
by ollyburton » Sun Nov 16, 2008 10:14 pm
hello there is this not on plans as depends on original joist size new joist size but 400 mm is safe enough
________
Suzuki SJ
billyboy999
loft beams
by billyboy999 » Fri Nov 21, 2008 6:17 pm
thanks olly, what size should bolts be. by the way my surname is burton as well.
mdpmspitfire
bolting joists
by mdpmspitfire » Wed Nov 26, 2008 9:48 pm
i would suggest using bzp m12 coach bolts or studding. use a large plated washer also. offset the bolts from the center line also to spread the compression which will help to minimise any splitting if the timber moisture content reduces in the new timber.
mark
TheDoctor5
by TheDoctor5 » Fri Jan 30, 2009 9:12 am
It is currently Mon Nov 25, 2024 8:26 am
