Loose window frames
RS
Loose window frames
by RS » Fri Nov 14, 2008 5:01 pm
Hi I have some upvc windows but they are loose in the brickwork you can move them about 2mm
Does any one have any ideas how to secure them?
Many thanks
tim reeve
by tim reeve » Mon Nov 17, 2008 9:39 pm
2mm is not much movment, check the screws each side of the window are done up tight,otherwise drill holes each side using sds 6.5 drill bit and fix with 100mm gold tap con bits,hope this helps.[/code]
mdpmspitfire
by mdpmspitfire » Fri Nov 28, 2008 8:53 pm
are the frames silicon sealed externally, this prevents movement usually, check the fixings are tight
TheDoctor5
by TheDoctor5 » Mon Jan 26, 2009 10:39 am
It is currently Fri Nov 22, 2024 2:34 am
