Cool Radiator
bugsy
Cool Radiator
by bugsy » Fri Nov 14, 2008 7:01 pm
Hi Everyone,
In my house i have several radiators and they all seem to be working fine except for the one in the TV lounge. This particular one is a lot cooler than the rest for some reason so i bled it but this did not do anything. It does have a TRV fitted but i have this on full so i am at a loss as to why it is not as hot as the others, any ideas?
nitro23456
by nitro23456 » Sat Nov 15, 2008 8:52 pm
seized TRV pin or system not balanced.
Steve the gas
by Steve the gas » Sun Nov 16, 2008 5:49 am
Hi Bugsy,
It will be the pin sticking.
Take the trv head off by unscrewing the collar,then pull the small pin UP about 2-3mm, and a squirt of wd40 on it, voila!!
Hth
bugsy
by bugsy » Mon Nov 17, 2008 8:52 pm
[quote="nitro23456"]seized TRV pin or system not balanced.[/quote]
How does one go about balancing the system or do i need to call somebody in.
bugsy
by bugsy » Mon Nov 17, 2008 8:57 pm
[quote="Steve the gas"]Hi Bugsy,
Hth[/quote]
Tried this but the pin is already as high as it will go. However around the pin is an hexagonal shaped gold plate. If i were to loosen this(if it can be loosened) will it let the pin to be raised higher.
It is currently Sat Jan 11, 2025 9:50 am
