Kitchen worktop
mancub
Kitchen worktop
by mancub » Fri Nov 14, 2008 7:13 pm
I have a washing machine under a kitchen worktop and need to drill a hole so that the plug can come up through the hole. But I want the piece that is cut out sit back in so the cut has to be angular
Any idea how to go about doing theis?
toptips
by toptips » Sat Nov 15, 2008 7:58 pm
why not cut the plug off ,then only a small hole needs to be drilled through the worktop the same size as the cable,
rewire with a new plug.
chris_on_tour2002
by chris_on_tour2002 » Sun Nov 23, 2008 11:39 pm
don't forget that when cutting, all material that comes into contact with the cutter turns to sawdust. hence the piece you remove will be smaller than the hole it leaves, so it won't sit back neatly. it will sit lower and not flush.
best option is as has already been suggested.
TheDoctor5
by TheDoctor5 » Fri Jan 23, 2009 8:47 am
It is currently Thu Jan 09, 2025 7:03 am
