SHOCKING!!!
sydlum
SHOCKING!!!
by sydlum » Sat Nov 15, 2008 11:15 am
Hello
If I remove an electrical switch box from a wall, what are my options with the exposed mains wire?
I don not have free access to the mains box, and so need alternatives???
Any suggestions would help - I have no clue whatever, and death is out of the question.
Thanks, Steve
kbrownie
by kbrownie » Sun Nov 16, 2008 6:13 pm
I hope I have this right these cables are still connected tom the fuse box/ consumer unit and are live! if so. If you are not removing the cables that are inside the back box, the cables must be terminated within the box and a blank plate put other the front where the switch plate was. It is important that the area the cable runs if still live are identified so by place a blank on it it will make you and others aware of the danger. You can not just joint up and plaster over.
KB
It is currently Mon Jan 20, 2025 4:13 am
