blocking up a fireplace
big-ernie
by big-ernie » Tue Nov 18, 2008 9:32 pm
I've been asked by a friend to block up a fireplace (which was covered over by a marble backing and an electric fire). I removed the surround, the backing and electric fire. I looked up the exposed flue and could see that the chimney isn't capped, but has wire mesh over the top to stop birds e.t.c making a visit. I plasterboarded over the opening and skimmed it, but was wondering what else needs doing :
1) do they need to get the chimney capped ?
2) do I need to put a vent in plasterboard ?
Any info apprechiated
fireplace
by welsh brickie » Wed Nov 19, 2008 11:16 am
you need to install a hit and miss vent in the plasterboard.
TheDoctor5
by TheDoctor5 » Fri Jan 30, 2009 9:33 am
It is currently Tue Dec 24, 2024 2:39 am
