Plasterboard
thedoctor
Plasterboard
by thedoctor » Tue May 30, 2006 4:31 pm
To post a question for a Diy Doctor tradesman or your fellow users, to answer please click on “New Topicâ€
dracs
Replacing lathe & plaster with plaster board
by dracs » Wed Mar 28, 2007 3:00 pm
1st time novice here trying to folllow my builders advice before he replasters the ceiling. I have a lathe & plaster ceiling which need to come down, I take it the lathe part is above the plaster skim and is of a soft plaster type consitency. I'm 95% sure on that. This all needs to come off says builder which I will attempt to tonight.
He then said tack 1/2 inch plasterboard. Do i get some plasterboard and just nail it into the joists, how much gap can I have between boards.
ta
omulcol
Re: Replacing lathe & plaster with plaster board
by omulcol » Wed Mar 28, 2007 9:05 pm
[quote="dracs"]1st time novice here trying to folllow my builders advice before he replasters the ceiling. I have a lathe & plaster ceiling which need to come down, I take it the lathe part is above the plaster skim and is of a soft plaster type consitency. I'm 95% sure on that. This all needs to come off says builder which I will attempt to tonight.
ta[/quote]
First, you have to consider whether the ceiling needs to come down in the first place. It's easier , and certainly cleaner , to leave the lath and plaster ceiling alone where possible - and overboard it with plasterboard.
Use overboard nails - or 3' plasterboard screws.
The joists can be located easily enough - they're normally fourteen inches apart . I use a string line to mark the centre of the joist from one end to the other ... as a matter of caution. These string lines are also useful for measuring the plasterboard accurately, and to always fix into the joists.
Gaps should be left ON the ceiling - and where possible try to keep the boards tight against the wall ... ie: no gaps - and the maximum gap needs to be 1 inch ...or less.
Much easier to use screws and a cordless drill rather than hammer and nails ... and two T frames ( dollys ) to hold the board up to the ceiling - leaving your hands free to fix the boards. !
dracs
by dracs » Thu Mar 29, 2007 3:56 pm
thanks for that. decided to take it off, did 90% last night as if i boarded it over it would encroach on the coving, i like the string idea to measure the boards. cheers again
It is currently Thu Nov 21, 2024 10:15 pm
