Door Handle
DevonSpeed
Door Handle
by DevonSpeed » Thu Nov 20, 2008 12:49 pm
Can someone tell me the best way to fix my door handle back on?
Its a normal brass plated one but the screw holes have become to big as the door is a cheap hollow one any suggestions?
Thank you
toptips
by toptips » Fri Nov 21, 2008 9:33 am
have a look at inter-screws
TheDoctor5
by TheDoctor5 » Fri Jan 23, 2009 8:46 am
thedoctor
by thedoctor » Sun Feb 01, 2009 11:29 am
You may have to glue a small, thin piece of timber over the screw hole to give the new screws some purchase. Sometimes its possible to move the hanle a couple off mm over to get to new wood on the door. Its a very common problem and sometimes a lager hole has to be made which will be hidden by the handle, to insert some timber up and inside the hollow door which is glued to the inside of the door skins. If you look at the DIY project on mending holes in plasterboard you can see how this would be achieved as the principle is the same.
sarah_9
by sarah_9 » Sat Feb 07, 2009 12:26 pm
Hello,
I know my suggestion is not very good one, but i`ll suggest you to call any carpenter to fix it, or try bigger screw,it could help you.
Regards,
sarah_9
Link remeoved -If you would like to advertise please go to our advertisers page.
It is currently Sat Nov 23, 2024 11:08 am
