no hot water from shower mixer/combi set up
meckev
by meckev » Sun Nov 23, 2008 12:44 pm
my shower mixer runs off of a combi boiler. but it never runs hot. if you turn the mixer on a little bit the water comes out at like a normal electric shower, at a decent pace, but there is no temperature control, the temp dial does not have any effect. sometimes the water will come hot for a moment but then go icy cold again. if you open the mixer fully, suddenly it runs at a realy high pressure. and stays cold. again the temp dial does not work no matter where it is. is there anything i can do to make this system wwork?
plumbbob
by plumbbob » Sun Nov 23, 2008 11:45 pm
Is this a thermostatic shower? Has it ever worked? Was the combi installed after the shower was fitted? What make/model of shower is it?
It is currently Sat Jan 11, 2025 9:43 am
