by Steve the gas »
Tue Nov 25, 2008 6:02 am
Are all your water pipes lead? If not come off some copper further upstream in plastic.
If all lead you can cut it at a convenient point and use a ' lead lock' fitting which will enable you to convert the lead to copper/plastic.
You will need the diameter of lead to get the right fitting.
Hth
