CENTRAL HEATING RADIATOR
romet
by romet » Tue Nov 25, 2008 12:10 pm
I want to get rid of my bathroom radiator and replace it with an electric one.
My question is, would it be enough to connect the two end pipes toghether after I remove the radiator so the central heating system will have a continuity. Do I have to modify anything else?
Thank you very much !![color=red][/color][color=darkred][/color]
plumbbob
by plumbbob » Tue Nov 25, 2008 8:27 pm
Do not connect the pipes together as hot water will use this quick route to bypass the rest of the system. Just cap the pipes off and leave them.
One note of caution though, bathroom rads are often used as a bypass, so if it is to be removed, ensure there is at least another rad on the system acting as a substitute. Bypass rads must remain open at all times, so must have any thermostatic valves removed, if a normal valve, the cap should be removed or replaced with a tamper proof lockshield type. Simply ensure the rad cannot be turned off by hand without the use of a tool.
romet
by romet » Wed Nov 26, 2008 12:41 pm
Thanks for your answer, before capping the pipes, I will close both taps on the bathroom radiator to see if other radiators throughout the house are heating up properly.
It is currently Sat Jan 11, 2025 10:40 am
